Finnster
KillaHurtz
Finnster's Avatar
02.24.2010, 08:24 PM
The easiest way to modify would be to simply shorten the legs on the existing top plate - I made the legs long enough and drilled and tapped the holes deep enough to allow this as an option. If you remove a known amount and move the mount holes for the front the same amount on the template, you have a smaller package that fits smaller diffs directly. :)
^^^ and that would be it lol
