02.28.2010, 03:18 AM
along with the reverse lever the hi/lo selector can be sketchy on non-forward only trannies.
If it's the slipper causing the problem you won't see the adjustment locknut turning, because that is the input shaft. If the nut is spinning the slipper is working and it is tranny related.
sounds like the reverse lever though....
