NovakTwo
Senior Strategist
02.28.2010, 07:59 PM
Originally Posted by slaytanic View Post
I was speaking of the Trinity motor. I have your 4.5HV and it is perfection in 4wd SC! Thanks for bringing it back. What will be different with the 550 ballistics? I have never used one. Is it mainly the ability to rebbuild with different winds and rotor?
The performance should be pretty much the same; it will allow the same timing adjustments as our 540 Ballistic (in fact, both motors use the same back end bell, bearing, and timing parts. Also, the shielded replacement harnesses and sealed socket.
We make "Frankenstein" 550s by adding the Ballistic parts listed above to our HV 550s. Here is the exploded view of our 540 Ballistic:
Novak Ballistic Motor
We can offer 550 replacement parts including wound stators, which may not be as easily damaged as the 540 stators.
Novak Electronics, Inc.
