squeeforever
squeeforever's Avatar
03.02.2010, 03:19 AM
Originally Posted by BP-Revo View Post
It's an H4 bulb for the Fog/High's. The factory low beam is a D2R (but obviously that'll stay as is).
From what I could find on my research, it's a single filament bulb and switching from low to high (in my case, fog to high) just adjusts a metal shield that alters the beam output. (I'm speaking of the HID's - obvious the stock halogen bulb is dual filament).
I just always read of people having issues with HID's flickering and not turning on and what not, and was wondering if having a relay would prevent this? I'm assuming it would since it would allow direct power draw from the battery, and therefore would not be limited to the power provided by the factory harness.
I don't think it would be a problem, but if it were, a relay probably wouldn't work to keep flickering down, but might. I just doubt it would help. I have HID's, and if you get a good kit, flickering shouldn't be a problem. Mount them well and you should be good.
Squee: The resistor you need depends on the voltage drop of the LED ("Vf" value) and the supply voltage you plan to use. Here is a page that should help you out: http://scriptasylum.com/rc_speed/_led.html
To have the LED on when the switch is on, you'd have the + of the LED/resistor go to whatever terminal the load is tied to.
BP: I really have no idea. Haven't done anything with HID, nor do I know what they are like. Sorry man.
Ok, so the + of the load goes to the common, and the - goes to the normally open, then the anode with a resistor goes to the common as well, and the cathode goes to?
