Finnster
KillaHurtz
Finnster's Avatar
03.05.2010, 03:15 PM
Originally Posted by scarletboa View Post
i never had much of a problem with pinions falling off until today. i got my rc-m motor mount and pinion for my truggy and i managed 2 30 sec. runs. each time, the pinion fell off. also, the teeth are already looking kinda sharp where the pinion and spur made contact. the mesh was good and it is a rc-m pinion. i have had pinions wear away slowly and none that have issues with staying on the shaft.
the rc-m pinion i ordered is decaying very fast. only ~1 min. of runtime and already the teeth are sharp. the only other time this has happened to me is when i used a stainless, non-hardened pinion. it's like my brand new rc-m pinion isn't even the least bit hardened. maybe it's just a fluke?
IDk. I once got a 14T RCM pinion that lasted less than a day. Perhaps they didn't harden properly. Perhaps contact Mike or just bite the bullet on a new one.
I use green locktite onthe shaft and blue on the screws. Green is for shafts & bearings, and it does hold the pinion on very tight.
