03.05.2010, 11:19 PM
OK, I hunted around the net a little bit for a simple proper 2-cell NiMH charger for these cells, and the best I could find was some USB-powered charger. It should work, but didn't like the fact that the reset function was not the best. So, I created my own circuit. I just breadboarded it and it looks like it works very well. Here's the schematic:
Although a bit unusual at first glance, it's pretty simple really, and was done from parts I had in my bins. The basic charge circuit consists of:
- R1: 6 ohm resistor rated for 1W or more
- Q1: TIP127 darlington PNP transistor. Should be on a small heatsink.
- R4: 100 ohm 1/4w resistor
- D1-D4: 1N4001 diodes
The diodes and R4 set up the biasing for the transistor in constant-current mode. R1 sets the charge current. With a R1 value of 6 ohms, the charge current is ~280mA. Two series NiMH cells are connected where stated.
The thermal peak detection portion of the circuit consists of:
- U1: Any general purpose SCR (or triac or thyristor).
- R3: Resistor to limit gate current
- R2: Resistor that along with the thermistor, provides a voltage divider.
- R5: Thermistor
Operation is pretty simple. The thermistor is physically placed in contact with the batteries. As the batteries heat up (signaling the end of their charge), the thermistor resistance drops. This causes more voltage to appear at the SCR gate until it turns on. When this happens, it essentially "shorts out" the biasing diodes D1-D4, and shuts off the charging transistor. The neat thing about SCRs is that once they are activated, they latch that way. So, even when the thermistor (batteries) cools off, the charger will not reactivate. You reset the circuit simply by removing power via a switch.
The thermistor is the one for my Eagletree logger, and the SCR used was not "ideal" (rated for 600v and something like 500A , but it's all I had). So I didn't list the actual values for R2, R3, and R5 since the real values would be quite different.
A regulated 6v, 0.5A power supply was used because a non-regulated supply would effect the voltage divider (R2 & R5). At that voltage, two NiMH cells can be charged at once. If you want to charge more cells, simply use two circuits at the same time in one enclosure. You can design it so that the supply is higher (like 12v) for charging 4 cells at once, but then you have to charge 4 cells at once all the time. Many devices use 2 cells, so I figured this would be more useful. Besides, 6v is a good value to use to keep power dissipation on the CC transistor low (~0.4w worst case).
In a few days, I'm gonna place an order for the proper components (SCR and thermistor mostly) so I can make an actual unit I can use on trips.
