new losi buggy speed build....
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
new losi buggy speed build.... - 03.07.2010, 10:39 AM
I love crazy fast speeds. i also like to get other people there who might need some help. there is about 10 of us now, where i live, who has knocked on the 100mph door or has already surpassed it..
after a few emails, i decided to put together a thread to show exactly how i got there so anyone else who wants to can do so without throwing a ton of cash at experimenting on how to do it.
so...the newest build:
i got a race roller from a friend of mine who wanted to beef up his e-maxx.
this is a 1.0 race roller.however, any losi 8ight buggy will work for all my mods.
so after some negotiation i traded him an FLM e-maxx chassis, flm front and rear shock towers, some battery boxes, flm front and rear skidplates and a monster mamba esc for the race roller. it was brand new, and i have 4 extra, never used chassis for it. i feel like i got a good deal.
anyway, i love the losi 8ights. i have 3 others and wanted to build another speed car.
here's the end result:
so here's a list of mods or equipment i found to be helpful:
1. tekin RX8 or monster mamba (or any esc that can run 6S)
2. neu 2650
3. losi rally tires(GRP) these stick awsome.
4. RC8 wing. this provides WICKED downforce.
5. 43t spur or a (45T steel spur)
6. 30T pinion (i have up to 35T as well) you can get them at Kershaw designs.
7. RCM motor mount (this allows for HUGE pinions)
here's a link for the pinions:
http://204.186.93.64/PinionsMod1.htm
i use these because i run steel spurs for the most part and they are alot more quiet than steel on steel.
however, if you want the steel pinions as well, you can get them here:
https://sdp-si.com/eStore/
look to your left and follow the way...
1. click on the arrow that says gears
2. click on spur gears
3. click on metal
4. select the pitch (mod 1 for the 8ight)
5. select the bore (5mm bore)
6. select the hub style. (hub with set screw)
this narrows down your material to steel or alluminum. i have both. i like the steel better
7. select the number of teeth and the rest of the fields will populate themselves with the rest of the information.
8. click on the part number and all the product details will pop up in a seperate window. if you click on the pdf file on the lower right, you can see it's a pinion gear now.
8. check out with your preffered method, and they'll be on the way.
shipping is a little pricey, but it's a good place to buy gears that otherwise would never be found in the RC market. So for me, it's a good buy.
more info.....
i always lock the center diff. A-Main hobbies carries a king headz diff locker for the L8ight that is amazing and only about $13 to buy:
http://www.amainhobbies.com/product_...ial-Lock-Spool
this is essential for the top speeds. i've tried up to 500k diff fluid before, and i can still unload the power to the front wheels so i always lock it.
center drive shaft pins...
mine used to fall out constantly. it drove me crazy. so here is a fix that will keep them locked in and safe:
i resigned myself to having to change the pinion coupler and the driveshaft at the same time, so what i do can't be undone.
i threadlock the screw, and the pin in and then i scuff the coupler and use a drop of jbweld over each hole where the pin sits and let it cure and dry for 24 hours. that will lock the pin in, and jbweld is good for 500+ degrees and works on virtually every metal surface. then i use the cvd boots for good measure. i haven't had one come loose or out since last summer when i did the mod.
I also threadlock the coupler on the shaft so it won't come loose.
for anyone who dosen't know, don't be afraid to threadlock anything. even with the strong locker. any heatgun will soften it up enough to get it off when you need to.
a word about tires....
imo, GRP makes the BEST onroad tires. Losi used to carry the GRP rally tires, but has since discontinued them. i still have quite a few sets left, but for those of you that don't have any, they can be had direct from GRP here:
http://www.grpgandini.it/index.php?p...chk=1&Itemid=6
i get them in about 4 days, and they are great with customer service.
i added a little bling too. the top plate, and the wing mount are aluminum, but don't really add anything but some aesthetic value.
so that's all i could think of folks!
in a couple of weeks, i'l be doing a speed RC8 and showing step by step how to mount a revo spur so you can enjoy those huge ratios, thanks to a Canadian friend who has already broken 100mph up north. I'm still waiting on a few parts on the build to come in.
any questions, let me know.
PEACE!
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
