littleazn248
03.10.2010, 12:39 AM
Wow nice work on the battery box! As far as shocks go i recommend something stiffer than what you have, it looks like your still using the original red springs. Id recommend getting a integy spring kit. For on road the stiffer the spring the better but not to stiff though, you wanna stiffen up so the car corners flatter, but if your to stiff they're will be to much lateral G causing the car to break traction (drift). Actually better yet I'd just recommend getting some revo shock since they have progressive rate so they slow and firm on the compression stroke and soft and quick on the rebound stroke the bore is also bigger than the emaxx shocks.
