Thread: Jammin SCRT10
Shark413
Shark413's Avatar
03.10.2010, 09:38 PM
Originally Posted by superek4 View Post
No just wonder what's the benefit as I am going to use 14mm shocks from x1 jammin cars.
The benefit is more travel. You want to increase the travel (in front) but you don't want to raise the ride height, so you need to increase the up-travel. The stock Jammin SCRT10 front shocks are really short and don't have enough travel. If you use the rear shocks in front (or any longer shock) you can gain some up travel. To use longer shocks you need the extended shock tower. Just don't get carried away with the front up travel as too much and your CVD's will bind under full compression. Use the SNR tower and stock Jammin rear shocks and you won't have any issues.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
