Thread: 4s or 5s or 6s?
kneedeeppow
is lovin life brushless
kneedeeppow's Avatar
03.14.2010, 04:21 AM
well w/the 2200 motor on 5s will be a lot faster....but if you really wanted an efficient set up, a 1500kv on 5s would be much better and would should give you a couple of extra minutes of run time if geared correctly.
I believe you can now get 5500 and 6000mah 5 and 6s li-po. The more mah, the more weight you add though.
i take it goin from a 2200kv to 1500 would be drop in overall speed and power? would it be super noticable? i like the idea of longer run times and there is definatly more power in the 2200 than i really really need.it just gives me far more than i need so a tone down might be in order.just dont want to drop to much tho,its still alot of fun with all that acceration
associated rc8t..........e
tamiya f104pro,r,w.f103gt.tb02,ta02
nuova faor sf501
avatar is pic of what our cat does with empty boxes left over from rc purchases
