slimthelineman
slimthelineman's Avatar
03.14.2010, 02:33 PM
thats nice.... like i said it was drop in for us. no 5mm pinions needed! and yes the 3.17mm shafts do break... in 8th scale setups because the cars wiegh 7.5+ lbs. i have used your hv motors before and was simply stating i preffer the trinity. i run against other guys using the hv on 2s with a havok pro and its fast... but not fast enough. they also run hotter on 2s than we do on 3s, not alot(~20-40degrees) but still. as far as debris inside the motor.... never been an issue, the holes are probably there as well as the fan because the motor is designed for an e-maxx which weighs twice what the slash 4x4 does. not trying to rain on anyones parade, simply saying this setup is working better than any other i have seen so far shy of a full blown 8th scale system. even then its only slightly faster.
