RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.14.2010, 03:28 PM
"If someone would be worried about the strength of a single screw shouldnt they be able to use the included bushing w/a longer screw and a washer slightly larger in diameter than the lower hole opposite side of the motor for more durability? Just a thought."
Yes, this could certainly be done if one was concerned. I think the concerns will be proven invalid, but this option is of course available at the cost of adjustment convenience(in reality, how often do you set gear mesh to begin with?).
"Brian, can you tell us how much the truck weighs, RTR with body on"
Mine weighed 6 lbs 13oz RTR with a 4s, 4000mah Hyperion battery(no body). I did not weigh it with the body. I used the 1900Kv Tekin buggy combo on my truck, so it is basically identical to Brian's. :)
