Originally Posted by BrianG
When you plug in your battery pack, the MMM will assume a freshly charged pack, which is ~4.2v/cell. So, the MMM may see a somewhat depleted pack as a fully charged pack of lesser voltage. This is why it is best to count the beeps when arming so that you know what the ESC sees.
Ok, that confirms what i was thinking, thanks!
Originally Posted by Finnster
You can force it to a cell count instead of auto detect if you always use they same voltage of batts.
If you plug in a nearly dead 4S pack, it may be read as 3S and set cut off V too low.
Ya i should probably do that since i only run 4s anyway.
