03.15.2010, 10:46 AM
As said in the other thread you started, 3" of ballooning is way off. That would make your tires look like pizza cutters, and should not be happening on a base speed of ~40mph - there simply isn't enough tire speed with that gearing you posted. Use a ballooning value around .5 for the gearing you are at.
