brian015
brian015's Avatar
03.15.2010, 08:59 PM
So now your only solid piece front-to-back will be the upper plate. Everything else is in three sections. I'm not sure, but will the CF plate be able to bear the brunt of the forces, or will it be a weak point?
Here's my thought: You could make the lower plate a single piece Al plate from front to back, but more narrow than your present center section (just as wide as the widest parts of the top plate. Then you could add CF "wings" in the middle as battery trays. If that makes sense.
