billy gunn
03.16.2010, 12:19 AM
The lower plate is thicker than stock - stock is 4mm, mine is 3/16 (4.8mm). I had to mill extra pockets so the plastic skid would fit. The motor plate and chassis brace(opposite motor mount) are .325" thick(8.3mm) and are attached through the bottom of the lower plate, to the top of the rear bulk plate and to the main chassis extrusion - it is quite solid/rigid.
Thanks, didn't even notice the first time around that you machined a new rear lower chassis plate. Will you have a motor plate with spacing for a 22xx Neu as well as the 15 series?
