03.16.2010, 01:23 PM
aluminum totwer would be a must have, i was thinking along the same lines earlier but i didnt have time to type it out.
youll want to spread the two links apart a the shock tower, one 8thscale shock standoffs (on backside of tower) would work great and spread the load point out a little this would also greatly increase the spread needed at the upper arm mount now i like the dual turn buckle setup since it allows adjustment of the caster which is important to be able to get right to make it handle well.
