Overdriven
Destroyer of Tires
Overdriven's Avatar
03.19.2010, 09:45 AM
Sorry I didn't like my post so I deleted it. I don't see a way to keep the emaxx shafts up front with a c-hub setup. Unless you use the stock slash 4x4 hubs with the old style thin maxx shafts and bearings with a bigger center diameter. I should have time this weekend to do some mockup on this to see if it'll work or not. Because other than the shafts, the truck seems to be pretty strong. Knock on wood, I haven't bent or broken anything else yet with all the abuse I've handed it.
But otherwise I'd just use the cvd that is designed for whatever c-hub setup you use. If the shaft is the wrong size, cut, sleeve and reweld it to the proper length. Pay for shipping and I'll do it for you no charge if you can't do it or don't want to pay for custom shafts. Then you'll just have to find a decent c-hub setup that'll work with the true tracs.
