Thread: Castle 1717
nitrostarter
nitrostarter's Avatar
03.19.2010, 06:39 PM
Originally Posted by Thomas Porfert View Post
They are 18-21mm, 20mm on average.
Same size bolt pattern, ~ 25.4mm center hole to center hole; 3mm screws on both.
That means you could fit a 1717 motor to the mini E-Revo tenbol mount. A motor that weighs more than the car? I don't see a problem with that! :)
Thomas Porfert
Castle Tech Support
Would be cool, but you couldn't gear it high enough to take advantage of the torque it makes. You you need an output multiplier...
N. Rustler conversion
