Originally Posted by Thomas Porfert
They are 18-21mm, 20mm on average.
Same size bolt pattern, ~ 25.4mm center hole to center hole; 3mm screws on both.
That means you could fit a 1717 motor to the mini E-Revo tenbol mount. A motor that weighs more than the car? I don't see a problem with that! :)
Thomas Porfert
Castle Tech Support
Would be cool, but you couldn't gear it high enough to take advantage of the torque it makes. You you need an output multiplier...
