E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
03.22.2010, 03:02 AM
dropping to a lower kV motor and the same gearing will give you slower speeds but longer runtime, less work is being done. With the lower kV motor if you gear for the same speed the same amount of work is being done and runtime will be about the same. The power that your motor is rated to handle and output is useless for figuring your runtime as was mentioned ( sorry for stepping on your tows PinkPanda) Hook up an Eagle Tree and you will see what kind of power your actually using. I have a few graphs of the 1515 2.5D in my RC8T and you may see very short bursts of about 2000watts but your average is much lower. I had a peak amp draw of 168A I think but my average draw was about 25-30A. Your driving style, throttle control, and gearing will play the biggest role in your runtime. You said you have 14-18T pinion, how is the speed for you with the 14T versus the 18t? If the 14T is enough speed on the track you will get longer runtime than with the 18T. I will be running a 50T spur and 15T pinion on my truggy to start the year running a CC/Neu 2200kv on 4s, speed should be pretty close to the 1515 2.5D (1650kv) on 5s, it might be a touch faster and I may drop to a 14T. As for batteries 4s 14.8V x 5000mah gives you 74 watt/hrs (voltage x amps) So a 5s pack of 4000mah should supply the same amount of power and give you the same run time, however running higher voltage will decrease the amp draw and create less heat, the lower amp draw will not yield longer runtimes though because the 4000mah battery has less mah to supply you power. If your in need of longer runtimes and you change nothing you need a bigger battery, like 6000mah+. Make sure everything moves smoothly in your truck, no binding anywhere. Tire choice affects runtime, lighter tires take less energy to rotate and will give you longer runtime, any thing that can be lightened up on your truck will help. Learning throttle control and rolling into the throttle rather than stabbing it and blipping the throttle like a nitro will help a tremendous amount!
I ran smaller batteries than another electric guy at the track, yet I could easily get 3-4 minutes more than him. He was better than me overall but he didn't have the throttle control and his idea of gearing up and then turning down the epa on his radio to get the speed down doesn't help either, the motor is still doing more work to get up to that speed.
Any other questions? Maybe talk to BrianG, he's the guru on here for giving you all kinds of formulas for figuring out amp draw and such
