03.23.2010, 12:51 PM
There was a ball mount that camewith the kit, you have to use it instead of the original and it is meant to go in the middle then. I beleive I may have had to useable sanding drum on my dremel still cause it was a bit tight still. Wanted to switch to the cc/neu hoping for a tamer setup, not that to much power is bad but if it was a little less it'd be nice. Also the smaller pack will be less weight, longest mains we ran last year where 12 minutes and I still had about 1/3 my battery left after a main. Also I like the wires. Oming out of the cc/neu ally better!
