Originally Posted by SunnyHouTX
I have to side with nuz69 in this one magman. I've read posts, some by CC personnel, that 4-pole motors should have higher timing. 2-pole motors definitely should have 0 timing whenever possible (I run some timing in my drag set ups but that's another story because heat is not an issue there). I run my Medusa 36-70-2000 at 8 - 10 degrees and my CC/Neu 2200 at 10 degrees and that has given me best results for temps and run times.
good point..i did run my Medusa at 10 deg. Well I may have to up my timing on my 1520 and see what happens. Although, at 0 timing, I have had no issues w/temps
