Originally Posted by Deahttub
Figured put what it was....the screws on my center diff backed out on the front side of the diff and dug into the tranny....the diff is fine, but the tranny has some serious grooves in it...looks like im looking for a new tranny....I fixed the center diff and gave it a test drive for one minute in the dark and it's running fine for now....
It sounds like you need some "Loctite". If you want to avoid having screws backing out on your rig you might want to start using loctite on your screws to keep them in place during heavy loading. Use the Blue loctite for screws you want to be able to remove regularly, and RED for those that are more permenant.
