Attila
02.13.2006, 06:15 PM
Originally Posted by E-maxx-kid
If it was running fine before hand why not just replace it for another 12020, ...
That's the point: I was not very happy with the controller. As I wrote in my first post: "The only unsatisfying thing with the 12020 was the fast and hard change-over from full-brake to reverse."
When the controller is in forward/brake/backward mode and I do a fullbrake then the trigger on the remote control is in full-backward position. And exactly that happens after braking: the motor goes fullspeed backwards. That's really a stressfull moment to the drive train! It would be much better if the controller would be waiting until the trigger is back in neutral position before changing from brake to backward mode.
Do you have the same problem with the 9920?
-- Dave
