Well I finally got batteries and all together and took the RC8T out for a run.
MMM/2200 using 50/16 gearing and 5S 5800MaH (Zippys). Motor was up to around 140 after some long high speed passes. Batteries were around 90. But the MMM fan came on.
Thoughts?
Originally Posted by suicideneil
As a rule of thumb those guidelines are correct, but there are always exceptions top the rule:-
way over geared - hot everything
motor too small/ underpowered = will run hot regardless of gearing
etc etc. What motor & kv & voltage were you using?...
