coolhandcountry
coolhandcountry's Avatar
02.13.2006, 07:15 PM
Use the stock length turn buckles and you have no problems. The ones that came with it is to long. It works if you use the stock sliders cause you can have the knuckles out far enough. As for the strobe slipper you need to take a fraction of the peaks on the input shaft. Just kind of knock the points down on it. I had the same problem with this system. I have the stock turn buckles and so does mike.
Peace!
Country
Help support the
Rc-Monster
Buy here
