Thread: 6s vs. 4s?
kingdomracer
kingdomracer's Avatar
03.27.2010, 10:28 PM
It's always so nice when someone comes along and clears up the fog in front of me, thanks. Now if you will explain to me the formula that you used to know that a 5000 mah 4s runtime is 15min. I already own a bunch of Enerlands that make up 2 sets of 4s and 1 set of 6s and they're 6000mah and using you formula they will be just 400mah under so they'll do just fine and should give me the same run time as my TP 8000mah 4s. I tend to stay away from 6s due to my share of fried MM ESC's but I cured that problem with xtra caps so I'll probably run a couple of laps with 6s just to see what it does but plan to run 1800kv 5s 47/12 setup on my 8 2.0
JESUS says "Fix it B4 it Breaks"
