03.30.2010, 03:06 PM
The XT8 is a pretty decent platform. However, I seem to keep bending the rear axle pins on the tire carrier; I've replaced them 3 times so far. I tried adjusting the spacers so that there is less strain on them, but if that doesn't work, I'm going to drill out the arms and axle carrier to use the same diameter pin that's on the diff hinge pin.
