03.30.2010, 04:33 PM
What kind of vehicle is this on? I Raced my RC8T all last summer with no problems. When I just tore the thing apart the only bearing I had to replace was on the steering post and that was because it was stuck there and when I tried pulling it off it blew apart. What kind of tires are you running? A huge tire will put more load on the bearing if it's even slightly off balance. Are you running offset rims? That will also put more load on the bearings.
