BL-revo
04.02.2010, 12:07 PM
hi guys, i have 3 sets of lipos for sale ( please note i will not split the lipos up unless 2 people are interested in 1 each...):
2 X Zippy-R 4500mah 21/30C 14.8v/4s lipos perfect for 1/8th scale setups. in good condition approximately 30 runs in total and matched to each other so you can use them in parallel for a whopping 9000mah single battery. an extra layer of clear heatshrink has been added for extra protection and one of the batteries has a small tear in the white heatshrink below this but this doesn't effect how it runs
2 X FTX 5000mah 20C 7.4V lipos again perfectly matched to each other so they can be used in series for 14.8V of voltage
(the heatshrink on the wire has cut near the exit of the wires from the hardcase but this has been taped and i can heatshrink before i send it out if you want. there are scratches on them but none are serious)
Enerland/ polyquest 18.5V 6000mah excellent top quality battery RRP of £160+ less than 10 cycles through it and double heatshrinked for extra protection
all prices include 2nd class recorded delivery if you want them insured (advised as recorded is covered only up to £39) i will find out how much extra it will cost.
