Attila
02.14.2006, 09:08 AM
Originally Posted by Dafni
Going into full reverse if you keep holding the trigger is exactly what it is supposed to do. Just release the trigger when the truck has stopped, it's easy. It won't go into reverse if the truck is still rolling.
Just release the trigger.
btw, I never use full brake anyway, it would flip my trucks over. (set EPA)
NO, I would expect that the controller acts like in this description (it's from MGM):
CAR mode forward / backward [A1]:
If the car is at standstill, then by moving the throttle from neutral the car will go backward or forwards. If the car is moving then by moving the throttle backwards the car will brake. The brake is proportional, that means the further the throttle is from neural the more intensive the brake is. The intensity of braking in the max throttle position may be set in parameter "B". When braking the car will stop, and not start moving backwards until you move the throttle to neutral and then again backwards. Connected braking lights are turned on when braking.
-- Dave
