simplechamp
simplechamp's Avatar
04.05.2010, 12:57 AM
No, you are geared for about 43mph, definitely not undergeared. The Tekin combo should be able to handle that fine though.
Maybe a bad connection or solder joint to one of the phases on the motor? Have you gone through the drivetrain to make sure there are no binding or worn out gears? Double check all your ESC settings to make sure everything is where it's supposed to be?
