thzero
04.05.2010, 02:22 PM
29/9
Not very far off from the 43/13 of the standard ones, i.e. 3.2 vs 3.3.
1350 on 5S might be a tad low in the rpm department. I'm looking at going with the 1.5y wind 1800 CN for a center diff conversion and like a 50/13 (could go with a 46/12 too) for target of about 45 with ProLine Badlands.
Good source of info.
http://scriptasylum.com
Also I should note that truggy diffs should probably drop right in with some shimming. I didn't fully test it, but I dropped in my RC8T diffs into the Savage bulkhead and with some minor shimming it rolled true. Didn't do anything to check the bevel gear for fitting.
Do you know the gearing of the BP diffs, If not I'll go look for it. Thanks.
