04.07.2010, 01:59 PM
I dont mind grinding down the stock mount a couple of mm to get the motor to fit...
How accurate is that speed calc? what do people usually punch in for how many inches does your tire balloon? I have Strapped HPI Dirt Claws with proline inserts. Maybe 1"?
What is more important for me is... Can i run this sort of gearing 44/25 with the 1800kv motor and not worry about temp issues and drawing too many amps from the ESC?
"using the same 44t spur equates to 32t pinion using the standard Flux gearbox. "
Im sorry i dont understand what you are saying? forgive my ignorance when it comes to gearing.
Yes i am currently running a standard flux gearbox... but i am hoping to replace the highspeed idler gear. I will quickly try and work out my new ratio... But how would i input the new ratio into the speed calc?
Also where do they stock the 1518 and what are peoples views on it as a motor to bash and do a few high speed runs? Should my temps be ok with this high gearing?
