IIICJACKIII
04.07.2010, 08:20 PM
The motor mount uses m3 on the top and m4 on the bottom - the screws for these should have been included. The battery tray requires 3 m4 screws and 1 m3 screw, which should be available from the stock parts IIRC.
thanks for the info. The two bolts for the batt.tray that go through the old nitro motor mount are a smaller counter sunk head (m3?) that uses a tapered washer to make them flat. the holes in the tray have a bigger insert(m4?) so i guess i will have to get some button heads for them. I tried the stock bolts in some of the holes and it felt tight after only one thread in. So i stopped, didn't want to strip any threads.
