Originally Posted by PBO
A bit more material for you Neil...
Tex, during or immediately after a hot shower...hold/pull the skin tight & use long strokes, not short scratchy ones. Go with the grain, then against. Rinse with warm/hot water, then you're done
doesn't going against the grain cause ingrown hairs?
i shaved against the grain....once...i ended up having dozens of ingrown hairs that i had to get rid of one-by-one.
my neck and jaw area break out pretty bad when i shave and there really isn't any pain or rash, but instead, acne and a lot of itchiness. i've cut down to twice a week because of this and it helps a little.
