Originally Posted by nitrostarter
Of course.
You can run a sensorless motor with a sensored controller as well, just be sure to disable sensored mode.
Not if it's a Novak esc! They will only run a sensored motor that has the thermal sensor. But a sensorless esc such as the MM, or MMM will run any motor that has a sensor, just be sure to secure the sensor harness so it doesn't get cought in any moving parts
