golfito
golfito's Avatar
04.11.2010, 02:27 PM
the feed is probably from the mmm internal bec.
remove the red wire from the mmm and place an external battery to the receiver and fix the problem.
then you should buy an external bec.
which of the cc bec buy:
cc bec?. It is less expensive.
application will comply with safely?
cc bec pro? I think oversized?
Thanks for your answers!
