Hey guys i think the castle 2200KV setup for a truggy is power enough for racing as long as it is setup properly in terms of gearing and voltages. However if you want to bash and have a good time and be capable of those really high speeds and not destroying motors or speed controllers than a bigger motor is the way to go. I run a NEU 1521 1Y (Castle motor not available at the time) in my MBX6T and a 1527 1Y in a G3R and temps and speeds are impressive to say the least. So are my run times. In my G3R i will get bored of doing the same circuit in the back yard before my LVC goes off. But if i want to do a speed run and try for 100mph plus i gear up and volts up and away i go. No issues except keeping it on the ground. The most valuable tools you can have in terms of electric setup are your temp gun and a data logger.
But remerber at the end of the day this is still a HOBBY and is supposed to be FUN. So have FUN
