itbvolks
04.15.2010, 06:11 PM
I'm not overly concerned about upping the voltage as the charger will just pull more current.
Being the voltage is 12.17v, provided there isn't a lot of line drop, it should be ok. Seeing as I'm looking to charge at 2c for my 4200mah setup your talking ~10A so with 30A main feed, I should have some headroom.
I'm more concerned about the board listing 12v1 and 12v2 nearest the power wires. In the bottom of the image, you can see the yellow/blacks 3pair and the 2pair under those (to the left). The 12v2 is listed right there. 12v1 is listed nearest the 2x 4pairs above (to the right).
