redshift
RC-Monster Square Tube
redshift's Avatar
04.16.2010, 11:12 AM
If you place the towline as low as possible, below the axle line, it will actually add some tractive weight, without adding weight. Theoretically it will spread the load better between the F & R diffs, and should keep both trucks from hopping. But too low (say ground level) could also transfer too much to the front and that would work against you... just thoughts.
