jappow
04.25.2010, 08:02 AM
Sorry for the wait, it's been slow going, pesty work keeps getting in the way of my hobbies. Well for beginers the gear box has changed . I changed the motor side to acomodate the carbon fiber top plate and to make it look a little better too. The next change was the front bracing that keeps the diff from roatating, to a cradle type.
Before I start cutting the CF chassis I would like to put sides on the chassis like Cody on his Savage project, but i dont know where there from. And the last issue to slove is the steering. I want the servo to be behind and more centered ,unlike a more traditonal E-maxx where its hangs out off to the side. So I need to find a good servo saver that is 180 degrees off rather 90 degrees that will mount on e-maxx shaft. Hope you all like the progress so far.
ID:	8810   Click image for larger version
