othello
HV basher
04.26.2010, 06:01 PM
Time for an update. I made quite a few changes since i posted the last time.
Motor: Neu 1521/1y (1577kv)
ESC: Castle MMM (Punch control 100%, Start Power low, Brake 50%)
Batteries: 7s2p A123 (21V avg)
Gearing: 1:14,56
I'm now using 1:5 GRP Bulldog Baja tires. I mounted them using extended 23mm proline wheel hubs. I wrapped the 23mm hex with a thin aluminium layer to compensate the difference between the 24mm wheel hex and the 23mm hubs. I extended th long rear center cvd with an 8mm steel tube. Unfortunately, i was not able to center it well onto the original cvd pieces. This is why it still wobbles at higher rpms and leads to heavy vibrations.
Picture of the actual test setup (wheighing around 15.65Lbs / 7.1Kg with eagletree logger)
Video of its first test run
According to my eagletree logger i'm using around 29A avg at 21V (around 600W). Peak Amp draw is between 100-125A (up to 2.3KW with the A123 pack). I'm using around 500mAh per minute which translates to an 8 minute runtime with 4000mAh. At 31000rpm with a 1:14,56 gearing top speed should be around 70kph (43mph). Due to the vibrations of the center cvd top speed is somewhat less. The Neu Motor can dissipate it's heat to the main chassis and remains relatively cool. Highest temperature so far 120°F (49°C) with ambient temps around 50°F (10°C).
After it's 4th test run on wet forest soil
Fitted with body and 5s2p 8000mAh lipos
Run on wet gras with an almost locked rear diff: video clip 1 and video clip 2
i tested 2 5s SLS 4000mAh lipos from a friend of mine wired in parallel on this run. AVG voltage 18-20V depending the state of discharge. Compared to the 7s2p A123 pack punch felt slightly better but top speed was slightly slower. Power levels remained comparable to the A123 pack: 600W avg and up to 2.6KW peak. With 7000mAh discharged a runtime of up to 14 minute is possible. Shortly after this test i ordered 2 6s 3600mAh lipos which will be paralleled too.
There are still a few improvements to make. The heavy 1:5 tires and the extended wheel hubs are hard to the suspension components. The center cvd has to be redone properly. And so on ...
ID:	8820   Click image for larger version
ID:	8821   Click image for larger version
