asheck
04.26.2010, 10:35 PM
Thanks. I would call this a success, however I'm not ready to make it my beater. I've had about 3-4 hours of runtime , and only had 1 nut loosen, and did rip a shock screw out of the rear RPM arm. That's better then my 3905 did, by far, and comes in at under 7.5lbs. But I think the main thing is it works on a handling, and fun factor, and while I'm sure it's not the strongest thing out there, it is the only one.
It took a couple jumps to get the hang of this truck. Being that it is still running on 2s, it has very little braking force, and is not near as easy to control in the air, as my E-revo. The shocks are just like the rear, Hyper 7 fronts. They work pretty good as mounted in the stock points, but a better multi-postion tower would be nice.
Speaking of 2s, I can't believe how good 2s is doing. I'm running right at 35mph, have very good torque, and have yet to see temps go above 120 on the motor. I'm getting an easy 45 minutes of runtime , before hitting lvc, this with 2 Blue lipos 5000mah 20c paralleled.
