04.27.2010, 11:52 AM
Hey there, get the plastic cup after everything is emptied and some fine grit sand paper.
Proceed on a very flat surface to rub the plastic cup on the sandpaper until everything is smooth.
This should level off any imperfections from the factory and should give you a way better seal :).
