Originally Posted by Nard Cox
Is there a way I could visually check that before sending it in ?
How long would it app take to check/fix it going from a cracked solder joint? Since I saw you guys were also planning on moving and all ;)
You don't have to worry about the move -- we are keeping our building that we are in now.
If you have a good quality microscope you can visually check it - -but you won't be able to see a cracked via (which is another possibility...)
-Patrick
