04.28.2010, 05:28 AM
Changing a MMM 2200kV combo with a tekin 2050kV buggy combo would be bad :( Tekin buggy motor are undersized for 40mph geared races and will overheat compare to your castle/neu motor :(
At least, use the castle motor if you want to keep same top speed and lap time, other than that you will have to gear the tekin lower if you don't want to kill it...
