04.28.2010, 03:37 PM
Not sure what happened to the MMM internally, but the RX8 has apparently had some issues with the type of solder being used, and it can crack/let go under heavy forces. Not a whole lot you can do really except use more/spongier foam. Weatherstripping, like suggested, works pretty well. It is softer than other stuff like craft foam, so it gives more.
