04.28.2010, 07:51 PM
Painted the shell on the outside- if you skip back a page or two you'll see what happend exactly with my painting attempt
Ah yes, specs:
Weight = 13lb 10oz ( without battery )
Total length = 24"
Wheel base = 18" ( currently, will end up a little bit shorter after I've tweaked it )
Track width = 20" ( outside edge of tires )
Total height = 10"
Groundclearance = 1.5" ( under front and rear axles, center is a tiny bit more )
